RE : RE :Issue of open file.
When I open one file and then try to open the second file, a window appears with the message 'To create a content tool, the source drawing must be saved. Please save the drawing.' As a result, I cannot open the file. What should I do in this situation?
Sorry for the inconvenience. The issue where the second drawing does not open properly when double-clicked in the file manager is currently under correction. From the second attempt onwards, please use the OPEN command within CADian to open the drawings. We are working on resolving this issue as quickly as possible and plan to upload the updated installation files soon.
