RE : RE :function keys and shortcuts
I want to use same function keys, shortcuts at home as those used in the office. Which program file do I have to install on my home laptop?
If you want to use the same shortcuts on a different computer, go to the Express menu at the top of the CADian screen, then navigate to Tools > Command Aliases Editor. Once there, click on 'File,' and you'll find options for exporting and importing. Export your saved PGP file, copy it to another computer, and then import it there to use the same shortcuts.
