RE : RE :Problem with command
I uninstalled version 6.0.25 due to issues, and then downloaded and reinstalled version 6.0.1. After importing the PGP file to ensure that the custom commands were working correctly, I installed GHK. However, I encountered problems with commands like copy, dist, matchprop in the command alias editor again. It seems like there might be a conflict with GHK. Is there a way to resolve this?
Thank you for asking!
I confirmed that even with GHK installed in version 6.0.1, command like copy and dist are working correctly.
However, the issue with matchprop seems to be due to overlapping commands. In version 6.0.1, I would like to request a change in the alias editor to replace the shortcut "ma" for matchprop with something else.
