RE : RE :"OK" button is not getting enabled
While studying for the Computer-Aided Architectural Draftsman Qualification, I need to insert a brick pattern into the exterior wall as a reference and move the origin point. However, even after going through the hatch options and selecting "Specify origin using a click," the "OK" button is not getting enabled.
You need to add a point selection on the boundary for the "OK" button to become active.
Thank you:)
