RE : RE :How can I check the current users of CADian software?
It seems like I've purchased an alternative to AutoCAD, and I would like to know if it's possible to check the current users of CADian software, similar to how I can use 'lmutil' to monitor network license usage for AutoCAD?
Yes, CADian also allows you to check the current users of their software through their CADian License Manager Watch program. When you run the program and go to "Local Host" > "Monitor" > "Current Users," you will be able to see the names of users currently using the software, similar to how you can monitor AutoCAD license usage. Thank you.
