RE : RE :How do I get rid of stretch points in CADian?
Using the EXTENDGRIPS command, the stretch points disappear for lines, but I don't know how to remove the stretch points as shown in the photo.
If you want to make the arrow disappear, you can run the GRIPS command and type 1 and then enter to make the arrow disappear.
