RE : RE :About vlx file
I want to use a vlx file, but it's not supported in CADian. IS there a way to convert it?
vlx file is a compiled LISP program that can only be executed within AutoCAD.
If you have the source code in LISP format before compiling, it can be executed, but once it's compiled, it can only run within AutoCAD.
Please understand that it's limited to running exclusively within AutoCAD after compilation.
Sorry for the inconvenience.
