RE : RE :About "MA" Command
Originally, when I used the "MA" command, clicking on the object I wanted to change would make the change. However, at some point, it started to require dragging instead of just clicking for the change to occur. Is there a way to revert it to the original behavior?
The "MA" command should indeed work as you initially described.
To return to the original behavior you're used to, I recommend resetting to the default settings and possibly reinstalling the software.
If you have any questions please feel free to ask us!
Thank you:)
