RE : RE :The command prompt disappeared. Is there a way to fix it?
After uninstalling and reinstalling AutoCAD2023 Pro, the command prompt disappeared. Is there a way to fix it?
Right now, it doesn't stay fixed, and I always have to press F2 to see it.
After uninstalling and reinstalling AutoCAD2023 Pro, the command prompt disappeared. Is there a way to fix it? Right now, it doesn't stay fixed, and I always have to press F2 to see it.
If you are inquiring about the command prompt, try pressing Ctrl+9, and the command input bar should reappear at the bottom.
If you have any more questions please ask us!
