RE : RE :Can you please explain why this is happening?
CADian 2021 Pro,
I am using relative coordinates (x, y) to specify the copy command, but when I try to copy an object relative to its coordinates, a new object keeps appearing at the origin (0,0) in absolute coordinates. Can you please explain why this is happening? And is there a command or icon to switch between absolute coordinates and relative coordinates?
CADian 2021 Pro,
Please press the F12 key to make the change and then proceed.
If you have any questions please feel free to ask.
