Thank you for asking and sorry for the inconvenience.
I will provide you with a solution to the issue you mentioned.
Control Panel > Clock and Region > Administrative options > Change system locale > At the bottom, uncheck "Beta: Use Unicode UTF-8 for worldwide language support."
If you encounter any further problems after using this method, please feel free to contact us.
