Can the APPLOAD used in AutoCAD also be used in Cadian?
For example, reading content saved in Excel as a drawing file (using AUTOLISP application).
Please check.
Hello, this is CADian.
You can use LISP files in the same way as AUTOCAD.
However, we do not support encrypted LISP or compiled applications like FAS, VLX.
