RE : There's an issue with the mouse cursor.
Hello!
Suddenly, the cross-shaped CAD mouse cursor has changed diagonally.
The line is drawn diagonally now.
Could you please advise on how to fix this?
Hello!
Hello, this is CADian. I will guide you on how to address this. 1.Execute the SNAP command. 2.Turn on snap, set snap spacing or: [Off(OFF)/Rotate(R)/Style(S)/Type(T)]/<10>: Enter "S" and press the Enter key. 3.[Standard(S)]/: Enter "S" and press the Enter key. 4.[Aspect ratio(A)]/Enter vertical spacing <17.3205>: Press the Enter key. Please check, and if it doesn't resolve, contact us again.
