RE : EasyMECH Installer
Sir/Madam,
We are having a site license of Cadian 2020, which I have installed on Windows 10. I have also installed EasyMech (also as admin). However, when I try to run EasyMech, I get the following error:
"Unable to recognize "EasyMech" command. Please try again"
I am attaching a screenshot of the same (with the problem underlined in red color). Please suggest a solution.
Thanks
---------------------------❓ 질문---------------------------
Sir/Madam, We are having a site license of Cadian 2020, which I have installed on Windows 10. I have also installed EasyMech (also as admin). However, when I try to run EasyMech, I get the following error: "Unable to recognize "EasyMech" command. Please try again" I am attaching a screenshot of the same (with the problem underlined in red color). Please suggest a solution. Thanks
---------------------------🎓 답변---------------------------
Dear Sir/Madam !
We will send you the EasyMECH installer of CADian 2020.
We will send the installer to your email address.
If you have any questions, please reply to cad@cadian.com
Thank you,
CADian Helpdesk
