FAQ · 2013.12.11
CADian VBA Sample Code - 28 [ Select Layer ]
CADian VBA Sample code - 28 [ Layer Selection ]
Dim objLayer As IntelliCAD.Layer
Dim strLayerName As String
strLayerName = TextBox1.Text
If Trim(strLayerName) = "" Then Exit Sub
Set objLayer = IntelliCAD.ActiveDocument.Layers(strLayerName)
If objLayer Is Nothing Then
Else
IntelliCAD.ActiveDocument.ActiveLayer = objLayer
End If
If Err.Number <> 0 Then
Err.Clear
End If
