FAQ · 2013.12.11
CADian VBA Sample Code - 12 [ Polyline ]
Creates a polyline from a list of vertices.
Signature
RetVal = object.AddPolyline(VerticesList)
Object
ModelSpace Collection, PaperSpace Collection, Block
The objects this method applies to.
VerticesList
Variant (array of doubles); input-only
An array of OCS coordinates used to create the polyline vertices. Each vertex is represented with three elements, with the first two being the X and Y coodinates in OCS; the third element is ignored. At least two points (six elements) are required for constructing a polyline object. The array size must be a multiple of three.
RetVal
Polyline object
The newly created Polyline object.
Remarks
To create a polyline containing arcs, first create the straight polyline, and then set the bulge at specific vertices using the SetBulge method.
This method exists for backward compatibility only. Use the AddLightweightPolyline method to create polylines with an optimized format that saves memory and disk space.
Coordinates can be converted to and from the OCS using the TranslateCoordinates method.
Dim myPline As Polyline
Dim myPoints As Points
Dim pt As Point
Set myDoc = ActiveDocument
Set myPoints = Library.CreatePoints
Set pt = Library.CreatePoint(1, 1, 0)
myPoints.Add
myPoints(myPoints.Count).x = pt.x
myPoints(myPoints.Count).y = pt.y
myPoints(myPoints.Count).z = pt.z
Set pt = Library.CreatePoint(3, 3, 0)
myPoints.Add
Set myPline = ThisDocument.ModelSpace.AddPolyline(myPoints)
myPline.Update
