FAQ · 2013.12.11
CADian VBA Sample Code - 4 [ Line Copy, Rotate ]
Private Sub Copy_and_Rotate()
Dim myLine As IntelliCAD.Line
Dim myStartPt As IntelliCAD.Point
Dim myEndPt As IntelliCAD.Point
Set myDoc = Application.ActiveDocument
Set myStartPt = Library.CreatePoint(4, 4)
Set myEndPt = Library.CreatePoint(7, 3)
Set myLine = myDoc.ModelSpace.AddLine(myStartPt, myEndPt)
myLine.Update
"" Copy and rotate the line
Dim copymyLine As IntelliCAD.Line
Set copymyLine = myLine.Copy()
copymyLine.Rotate myStartPt, 10
MsgBox "Rotated the copied line 10 radians."
End Sub
End Sub
