CADian VBA Sample Code - 3 [ ARC ]
Private Sub CommandButton1_Click() - Draw an ARC using given centerpoint, Radius, Start angle, and End angle for ARC.. - objectVariable = object.AddArc(Center, Radius, StartAngle, EndAngle) - * Center - Variant(Double 3 element Array ); Input only - 3D WCS coordinate for pointing the centerpoint of ARC. - Radius - Double ; Input only - Radius of ARC. - StartAngle , EndAngle - Double ; Input only The start and end angles, in radians, defining the arc. A start angle greater than an end angle defines a counterclockwise arc. Dim icadDoc As Document Dim myArc As Arc Dim cenPt As Point Set icadDoc = ActiveDocument Set cenPt = Library.CreatePoint(4, 2) ""Add the arc to the .dwg Set myArc = icadDoc.ModelSpace.AddArc(cenPt, 3, 1, 3) "" Display the entity myArc.Update ThisDocument.ActiveViewport.ZoomExtents MsgBox "Arc created w/ center point at 4,2." End Sub |
