FAQ · 2008.08.20
AutoCAD's FAS or VLX
* Question :
I believe that CADian supports an equivalent to the AutoCAD FAS files.
How can we produce these files for CADian ?
Do they work exactly the same as AutoCAD""s FAS ?
How are they loaded in CADian ?
It""s from only AutoCAD.
You can do [FLX] almost function, from CADian for it.
(However, it""s used one by one though VLX support lots of Lisp and DCL at one time)
1. This exists at folder of CADian 2008.
Files are LSP2ELFPro.dll and LISP2ELF.exe
2. Execute the LISP2ELF.exe in advance.
(If any error while executing the LISP2ELF.exe , please reuse that after register as listed below)
* Click [START] which shows lower left of Windows O/S >> Click [Run...] >> Register LSP2ELFPro.dll with regsvr32.
ex)) regsvr32 C:\Program Files\CADian2008\LSP2ELFPro.dll
3. Execute the LISP2ELF.exe
Please feel free to contact us , help@cadian.com , if any..
