FAQ · 2013.12.11
CADian VBA Sample Code - 24 [ SaveAs]
Save the documents or Menu Groups as specified file.
Object.SaveAs FileName, FileType
""FileName : String; Input-Only
""Total Path and name for file
""New name will be used for active documents or Menu Group.
""FileType : Type to be saved
""vicVersionR13
""vicVersionR14
""vicVersionR2000
""Drawing can be saved only as DWG format.
""To save the document as another format, use Export method.
Application.ActiveDocument.SaveAs "C:\testing", vicVersionR2000
