FAQ · 2008.08.21
Paste the Block
There is a file with a block.
When use CTRL + C and paste using CTRL + SHIFT + V in the same file, not ok.
I tried to use Edit > Paste as Block too, but I can’t.
* answer :
It works normally, but it cannot be worked when the limits is set as 'on'.
'Limits=on' was the reason why it didn't work.
So set the limits as 'off'.
