FAQ · 2008.08.01
What are the formats in which one can import / Insert data in CADian?
Currently, CADian can import and export the dxf, dwg and dwf formats. [ Import ]    1. Pull down menu : File    2. Import    3. Following file formats can be imported !      => dwg, dxf, dws, dwf, dwt, dgn, wmf and dae Apart from these CADian can also open most popular raster formats like jpeg, tif and bmp etc. [ Insert ]    1. Pull down menu : Insert    2. Image    3. Attach Raster Image    4. Select the image file format from 'All supported files(*.*).      - Many image file formats are supported !
